Strona główna › Fora › Forum wsparcia › Podstawy › [SOLVED] Gry na gry.pl się zacinają
- Ten temat ma 5 odpowiedzi, 3 głosy, a ostatnio został zaktualizowany 10 lat, 7 miesięcy temu przez
damian123.
- 31 sierpnia 2015 o 08:50 #710
damian123
UczestnikDrugi problem jest z grami na gry.pl i innymi opartymi na flashu. Po chwili grania nagle się zacinają i nic nie można dalej robić.
Kernel: 3.18.20-1-MANJARO x86_64 (64 bit gcc: 5.2.0) Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: ManjaroLinux 0.8.13.1 Ascella Machine: System: Acer product: Aspire E1-571 v: V2.04 Mobo: Acer model: EA50_HC_HR v: Type2 - Board Version Bios: Acer v: V2.04 date: 09/14/2012 CPU: Dual core Intel Core i3-2328M (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8783 clock speeds: max: 2200 MHz 1: 2199 MHz 2: 2199 MHz 3: 2200 MHz 4: 2200 MHz Graphics: Card: Intel 2nd Generation Core Processor Family Integrated Graphics Controller bus-ID: 00:02.0 Display Server: X.Org 1.17.2 driver: intel Resolution: 1366x768@60.01hz GLX Renderer: Mesa DRI Intel Sandybridge Mobile GLX Version: 3.0 Mesa 10.6.5 Direct Rendering: Yes Audio: Card Intel 7 Series/C210 Series Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0 Sound: Advanced Linux Sound Architecture v: k3.18.20-1-MANJARO Network: Card-1: Broadcom NetLink BCM57785 Gigabit Ethernet PCIe driver: tg3 v: 3.137 bus-ID: 02:00.0 IF: enp2s0f0 state: down mac: <filter> Card-2: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k bus-ID: 03:00.0 IF: wlp3s0 state: up mac: <filter> Drives: HDD Total Size: 320.1GB (40.9% used) ID-1: /dev/sda model: WDC_WD3200BPVT size: 320.1GB Partition: ID-1: / size: 19G used: 6.7G (37%) fs: ext4 dev: /dev/sda1 ID-2: /home size: 274G used: 116G (43%) fs: ext4 dev: /dev/sda3 Sensors: System Temperatures: cpu: 65.0C mobo: N/A Fan Speeds (in rpm): cpu: N/A Info: Processes: 190 Uptime: 2 days Memory: 1606.7/5787.9MB Init: systemd Gcc sys: 5.2.0 Client: Shell (bash 4.3.391) inxi: 2.2.2831 sierpnia 2015 o 10:28 #711
aquilaModeratorJakiej przeglądarki używasz do gier i czy tak samo dzieje się na 2 innych (np. chrome, firefox).
Jaki flasz masz zainstalowany?
Podaj wyniki:pacman -Qs flashplugin pacman -Qs chromium-pepper-flash31 sierpnia 2015 o 11:20 #714damian123
UczestnikUzywałem mozilli, na operze i chromium wyskakuje komunikat że należy zainstalować flash player.
Po wpisaniu
local/flashplugin 11.2.202.508-1 Adobe Flash PlayerPo tej drugiej komendzie nic się nie pojawia.
31 sierpnia 2015 o 12:59 #715
aquilaModeratorWykonaj jako użytkownik:
yaourt -S chromium-pepper-flash
orazyaourt -S freshplayerplugin
Oba pakiety są z AUR. Więcej o AUR tutaj.31 sierpnia 2015 o 13:23 #716pavbaranov
UczestnikTwoja karta demonem prędkości raczej nie jest. Flash od lat ma problemy ze swoim działaniem, w tym z wydajnością. Możesz sobie zobaczyć na:
konfiguracja Flasha, próba poradzenia sobie z marną jego wydajnością, popróbować ustawień Intel GMA.
Całkiem możliwe, że zdecydowanie wydajniejszymi okażą się przeglądarki, które wykorzystują PepperFlash (np. Chromium, Opera).31 sierpnia 2015 o 13:41 #719damian123
UczestnikZrobiłem to co napisał aquila, na chromium zaczęło działać, jak na tą chwile wszystko sprawnie działa. Dziękuje za pomoc.
