Strona główna › Fora › Forum wsparcia › Oprogramowanie › Xampp, bitnami, worpress
- Ten temat ma 0 odpowiedzi, 1 głos, a ostatnio został zaktualizowany 7 lat, 8 miesięcy temu przez
henry.
Wyświetlanie 1 wpisu (z 1 w sumie)
- 8 lipca 2018 o 22:40 #7886
henry
UczestnikZainstalowałem xampp z oficjalnej stony poniewaz w aur był out of date. W panelu zarządzania sprawdziłem wszystkie serwery działały. Doinstalowałem bitnami z WordPressem i niestety apache teraz nie wstaje :/ Jak go przywrócić do działania? Poniżej Error log.
[Fri Jul 06 22:44:26.997660 2018] [ssl:warn] [pid 16789] AH01906: www.example.com:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?) [Fri Jul 06 22:44:26.997770 2018] [ssl:warn] [pid 16789] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name [Fri Jul 06 22:44:26.997866 2018] [suexec:notice] [pid 16789] AH01232: suEXEC mechanism enabled (wrapper: /opt/lampp/bin/suexec) [Fri Jul 06 22:44:27.094019 2018] [ssl:warn] [pid 16790] AH01906: www.example.com:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?) [Fri Jul 06 22:44:27.094092 2018] [ssl:warn] [pid 16790] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name [Fri Jul 06 22:44:27.094308 2018] [lbmethod_heartbeat:notice] [pid 16790] AH02282: No slotmem from mod_heartmonitor [Fri Jul 06 22:44:27.136897 2018] [mpm_prefork:notice] [pid 16790] AH00163: Apache/2.4.33 (Unix) OpenSSL/1.0.2o PHP/7.2.6 mod_perl/2.0.8-dev Perl/v5.16.3 configured -- resuming normal operations [Fri Jul 06 22:44:27.136997 2018] [core:notice] [pid 16790] AH00094: Command line: '/opt/lampp/bin/httpd -E /opt/lampp/logs/error_log -D SSL -D PHP' [Fri Jul 06 23:00:06.993688 2018] [mpm_prefork:notice] [pid 16790] AH00169: caught SIGTERM, shutting down [Fri Jul 06 23:00:09.918339 2018] [ssl:warn] [pid 20133] AH01906: www.example.com:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?) [Fri Jul 06 23:00:09.918429 2018] [ssl:warn] [pid 20133] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name [Fri Jul 06 23:00:09.918536 2018] [suexec:notice] [pid 20133] AH01232: suEXEC mechanism enabled (wrapper: /opt/lampp/bin/suexec) [Fri Jul 06 23:00:09.995703 2018] [ssl:warn] [pid 20134] AH01906: www.example.com:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?) [Fri Jul 06 23:00:09.995759 2018] [ssl:warn] [pid 20134] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name [Fri Jul 06 23:00:09.995940 2018] [lbmethod_heartbeat:notice] [pid 20134] AH02282: No slotmem from mod_heartmonitor [Fri Jul 06 23:00:10.023926 2018] [mpm_prefork:notice] [pid 20134] AH00163: Apache/2.4.33 (Unix) OpenSSL/1.0.2o PHP/7.2.6 mod_perl/2.0.8-dev Perl/v5.16.3 configured -- resuming normal operations [Fri Jul 06 23:00:10.024060 2018] [core:notice] [pid 20134] AH00094: Command line: '/opt/lampp/bin/httpd -E /opt/lampp/logs/error_log -D SSL -D PHP' [Fri Jul 06 23:03:53.786261 2018] [mpm_prefork:notice] [pid 20134] AH00169: caught SIGTERM, shutting down - AutorWpisy
