Strona główna › Fora › Forum wsparcia › Oprogramowanie › Dysk google w linuksie
- Ten temat ma 5 odpowiedzi, 3 głosy, a ostatnio został zaktualizowany 8 lat, 2 miesiące temu przez
Mojz3sz.
- 19 kwietnia 2017 o 14:30 #3617
macieslaw
UczestnikJakie oprogramowanie polecacie do obsługi dysku google oprócz Insync który jest płatny? Oczywiscie program z GUI a nie w konsoli.
Próbuje zainstalować ocamlfuse ale wywala błąd.Compiler support generation of .cmxs.: ............... true OCamlbuild additional flags: ......................... Create documentations: ............................... true Compile tests executable and library and run them: ... false pkg_gapi_ocaml: ...................................... /usr/lib/ocaml/gapi-ocaml pkg_fuse: ............................................ /usr/lib/ocaml/Fuse pkg_sqlite3: ......................................... /usr/lib/ocaml/sqlite3 pkg_threads: ......................................... /usr/lib/ocaml pkg_camlidl: ......................................... /usr/lib/ocaml/camlidl tput: No value for $TERM and no -T specified Finished, 1 target (0 cached) in 00:00:00. tput: No value for $TERM and no -T specified File "_tags", line 32, characters 22-31: Warning: the tag "pkg_oUnit" is not used in any flag or dependency declaration, so it will have no effect; it may be a typo. Otherwise you can use <code>mark_tag_used</code> in your myocamlbuild.ml to disable this warning. File "_tags", line 35, characters 18-27: Warning: the tag "pkg_oUnit" is not used in any flag or dependency declaration, so it will have no effect; it may be a typo. Otherwise you can use <code>mark_tag_used</code> in your myocamlbuild.ml to disable this warning. + /usr/bin/ocamlfind ocamlopt -g -linkpkg -package Fuse -package camlidl -package gapi-ocaml -package sqlite3 -package threads -thread src/appDir.cmx src/utils.cmx src/buffering.cmx src/config.cmx src/cache.cmx src/concurrentGlobal.cmx src/keyValueStore.cmx src/state.cmx src/threadPool.cmx src/context.cmx src/gaeProxy.cmx src/mime.cmx src/oauth2.cmx src/drive.cmx src/gdfuse.cmx -o src/gdfuse.native File "_none_", line 1: Error: Cannot find file /usr/lib/ocaml/camlidl/com.cmxa Command exited with code 2. Compilation unsuccessful after building 47 targets (0 cached) in 00:00:01. E: Failure("Command ''/usr/bin/ocamlbuild' src/gdfuse.native -tag debug' terminated with error code 10") ==> BŁĄD: Wystąpił błąd w build(). Przerywam...19 kwietnia 2017 o 14:58 #3618pavbaranov
UczestnikWg wiki Archa masz w AUR takie możliwości: google-drive-ocamlfuse, drive, grive, gdrivefs, insync, gdrive z czego płatne jest wyłącznie insync (po trial). Z tego co widzę, prawdopodobnie jedynie pierwszy wymaga mnóstwa zależności, które są w AUR i trzeba je budować (nadto samo jest już w nieaktualnej wersji). Także gdrivefs wymaga zbudowania jakichś dodatkowych zależności z AUR (ale to python).
Z tego co widzę, to przynajmniej 3 spakowały się bez najmniejszych problemów: gdrive, grive, drive. Pierwsze uruchomienie – najczęściej z konsoli (bo skonfigurować). Potem można myśleć o jakimś podłączeniu/wtyczne do menedżera plików itp. Wszystkie bowiem rozwiązania, które są w AUR po prostu umożliwiają jedynie “dogadanie się” z GDrive, ale nie zapewniają (jeśli się nie mylę) GUI.
Spróbuj – to o co pytasz, to są kwestie użytkowe. Każdy z nas ma inne preferencje. Coś, co jednemu pasuje – innemu niekoniecznie.29 stycznia 2018 o 18:39 #6646macieslaw
UczestnikKorzystał ktoś z Overgrive? https://www.thefanclub.co.za/overgrive
Na razie testuje i jest OK. Warto płacić 5 dolarów? Bo insync troche za drogi.30 stycznia 2018 o 17:00 #6654Mojz3sz
UczestnikJa osobiście polecam grive. Nie jest jakiś mocno rozbudowany ale mnie wystarcza. Nie wykonuję jakichś “karkołomnych” rzeczy ze swoimi plikami na Dysku Google więc program w sam raz do zwykłej synchronizacji.
30 stycznia 2018 o 17:19 #6655macieslaw
UczestnikGrive testowałem, ale nie mam czasu na zabawy w konsoli.
Ten overgrive jednak do kitu. Usunął mi katalog z plikami i narobił puste kopie tego katalogu z numerkami 1 2 3 4. Dane z tego katalogu stracilem.Ktos uzywa Insync? Czy warto to kupic?
31 stycznia 2018 o 12:51 #6664Mojz3sz
UczestnikW sumie zawsze możesz sobie zrobić gotowy skrypt i przypisać go pod jakiś klawisz (kombinację klawiszy), albo jakiś skrót na pulpicie.
Dla mnie wygoda bo i tak używam I3wm. - AutorWpisy
